We recently installed one of those Jackson power steering kits onto our L2500 without power steering. The pressure line for the orbital steering valve tees right into the output line on the hydraulic pump in front of the brake pedal, then there are two hoses for the hydraulic steering cylinder, and one return hose threaded into the oil fill cap behind the shifter.
We primarily use this tractor for moving around boats on trailers. We've been noticing the drawbar is having a hard time picking up the trailers since installing the kit. I've read the relief valve can be shimmed. Is this a viable solution to this problem.
Hydraulic oil was recently changed and the level is fine.
