Kubota L1500DT Hydraulic Issues / No Brakes
stealth
L1500dt
Dec 14, 2014
Australia
Hi All
Newbie here
I bought the above unit some time ago, but havn't used it much
I have a small bucket and slasher attachment that I run on it, all systems were go until suddenly the Implement Hydraulics would not operate..... after a short run up time without reaching operating temp
Have cleaned screens x 2 under rear axle
Where is the Hyd tank to change oil and flush using 30w Kubota Oil
Checked for air and water ingress ( all good ), pump has pressure so they tell me
Implement control Levers x 2 are working have had them checked
Where do I find the brakes to check and service them as it has very very little
Any help will be greatly appreciated
7,232
Your tractor is similar to a L175 model
I don't have that WSM but I have the L185 WSM, very similar to your set up.
I'll PM you a download link.
The hydraulic reservoir is the entire transmission and rear end.
Corney
L1500DT, front end loader, mower, tiller, snow blower
Spent the morning figuring out the hydraulic system on my L1500DT.
Apparently the three point hitch has to be up in the highest position before the bucket while work? That took a while to figure out!
We just changed all the fluids and Forgot to clean those screens out. Can you share where they are in a photo?
No problem with the brakes yet so I can't help you there, sorry bout that.
