Kubota hydrostatic
Pete7
Western ny
Anyone know if Kubota used hydrostatic units made by Kayaba on there compact tractors? I have a kayaba (KYB) HVFD 23c23-m unit off a Ford 1620 and if kubota also used this hydrostatic model then I might be able to get parts from Kubota that aren’t really available thru Ford.
Be happy if you got a Kubota, cause Ford want $2k for the hydro’s complete charge pump when I only need the 2 rotors in the pump.
10,014
No, Kubota only uses Kubota Hydrostats on tractors.
The lawn equipment is the only equipment that uses other manufactures.
Old Machinist
May 27, 2024
586
688
NE FL
eBay may be your friend?
6,335
Even if you could find them the chances of that fixing your pump are not very good
JonM
L6060,SA20,4in1,BH92,QH16,BS40,APS1572,RTR2570,HR2572,WC1504,FM2584,SBP1684
Nov 29, 2024
175
364
wisconsin
As @North Idaho Wolfman said kubota uses their own hydrostats in tractors. But consider yourself lucky to be able to buy a new hydrostat for only $2k. Most old kubota hydrostat units are much higher than that
he is lucky ford will even sell him one.
