Kubota HD1101A vs DH1101
banochris
Kubota L245F with BushHog 1846QT Front End Loader
Jun 15, 2025
Georgia, USA
According to the ID plate, I have a Kubota L245 - 11430 with a DH1101A engine, and the engine is blue. I've found some used part that say they came from an L245 with a DH1101 engine and it's orange. Other than the color, does anyone know what the difference in the 2 models are?
6,686
Just a thought - - check Kubota Tractor Corporation - Illustrated Parts List
Not sure what engine parts you're looking at - -
Guessing there's a serial number break for the L245 between the DH1101 and DH1101A?
Maybe some parts are interchangeable, and others are not?
Check to see if the part numbers are common between the two.
banochris
Jun 15, 2025
Georgia, USA
Thanks. The nuts got sheered off the top of the Governor Lever. The Governor Level is the tough one to find. I found a whole assembly on eBay, and it's orange where mine is blue. I'm thinking cause it's the whole assembly, it may not matter as long as the spring and gasket fit.
The parts I'm hunting are:
LEVER, GOVERNOR Part # 15221-56020 -ASSY LEVER GOVERNOR
KEY, FEATHER Part # 05712-00408
NUT Part # 02112-50080 qty 2 of these
O RING Part # 04816-00120 04811-00120-replaces #04811-00120 O RING
WASHER, PLAIN Part # 04013-50080
COLLAR Part # 17011-57384 - replaces #17011-57380 PLATE FRICTION
GASKET,SP.CONT.P Part # 15296-57210 - replaces #15221-57210 GASKET CONT.PLATE
Workerbee
Zd21
Mar 1, 2020
291
147
MN
Why not contact that ebay seller and explain your situation? Maybe he would sell it with a return period of time.
