i bought a B7100 that came with this tiller and i have a few questions .
#1 does anyone know where i might find an owners manual that i could download off of the net ?
#2 where the two pins on the tiller connect to the three point , one pin was pointing towards the outside of the tiller and the other was pointing towards the inside . i took the one that was pointing towards the inside and reversed it so that both are pointing out now. is this ok or should i have left it alone ?
#3 on the left side of the pic you will notice some aluminum foil on top of the tiller . there is a hole there which i'm guessing is a filler hole . if so what type of fluid do i put in there ?
#4 the tiller had sat in a sandy area uncovered with no plug over that filler hole for several years . do you think it would be a good idea to take the side cover off and make sure that it is clean inside before filling and is that gasket available in case i mess it up ?
botaman .
botaman .
