whitetiger
Can you clear up your statement of; "a seal on the front of the pto shaft and they didn't have to split the tractor but had to tear down the front end and replace the seal."Looking for advice on how I should handle an issue I am having with my local dealer. Two months ago I took my L3240 in for a leak from the bell housing area. I asked them to split the tractor, replace any and all seals inside the bellhousing and then replace the clutch if it was soaked in fluid. I also asked for a price on a fuel tank since one of the vent lines had broken off and also for a price on resealing the front hub seals as they were lightly seeping. They called back and said their is a bulletin and it was a seal on the front of the pto shaft and they didn't have to split the tractor but had to tear down the front end and replace the seal. Total to fix the leak from the bell housing, and reseal the front hubs $1400 and $300 for the tank if I put it in myself after. I reiterated that I felt the leak was coming form the bellhousing. They insisted it wasn't so I agreed to the repairs. After numerous reasons ( parts delays) (work schedule) etc and 5 weeks time they called and said it was done. I picked it up and the mechanic told me I really should have replaced the front hub because the spline was butchered from a previous repair ( news to me as nobody called and said anything but apparently they increased the labor to cob it back together) already annoyed I started pulling on the trailer and it started dripping from the bell housing. I went back inside and they said it's residual... First job I went to it started leaking out the bottom consistently throughout the day drip drip drip. I took it back. Now after 2 weeks of looking at it and having a Kubota rep come out they have determined it is in fact a seal in the bellhousing and they want $1700 to fix. I lost it on the phone and they said they would talk it over and call back. Now they are saying $1200 and they will refund some of the first repair. Is this reasonable?
