Kubota d722 flywheel
Reelgolf14
Kubota d722
Dec 29, 2022
Pennsylvania
Hi everyone
Had to remove flywheel to replace bolts on rear plate. Can I just slap flywheel back on in any orientation? There’s a mark to align with starter pointer.
rentthis
1,009
25
summerville,sc
Those flywheels have a certain bolt pattern. Turn it until all the holes match and bolt it up. If you can get all the bolts in, it's right.
kubotasam
Apr 26, 2010
1,206
129
Alfred Maine
If you can get all the bolts in by hand , not with a wrench.
7,255
As other have said, no marks you just need to line up the bolt pattern.
Thread all bolts past the collar on the bolt by HAND, if they won't go in then you have the alinement wrong.
5,324
2,001
there is sometimes a witness mark on the back side of the flywheel where it mates up to the crank. Look at the crank and flywheel. Some of them had maybe a little half-drilled hole in the crank, and that hole would leave a witness mark on the flywheel. Line em up and hand tighten all bolts.
ONE of the 6 bolt holes is not the same distance apart as the others and it's kind of a pain to line em all up.
