Kubota BX2660 – electrical power loss
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
Columbia, CT
Kubota BX2660 – power loss on headlights, dash lights, digital tachometer, lift pump and gauges. Glow plugs, 12 volt accessory port , and hazard lights still work – all the fuses on the panel tested good including the 50 amp main fuse, battery is full voltage and cranks up in seconds despite no lift pump -any suggestions?
2,219
mice? wiring chafed?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,143
940
Williamstown Ontario Canada
What is battery voltage when the engine is running?
I want to see if the alternator is charging.
The alternator has a three wire plug in terminal where one of the three wires is a signal to the tach so it can display engine rpm.
Dave
JeepinMaxx
Mar 27, 2018
296
Columbia, CT
Thanks for the feedback - voltage running is 12.7 volts. Can't see any damaged wires. Ran it for a couple hours doing leaves on thanksgiving no problem - just no gauges, tach/hour meter, lights (glow plugs worked fine)
4,151
I downloaded the WSM from KB...
From what doesn't work, I suspect an open ground. Grounds are black wires.
Dash, headlights, fuel pump, etc. should all have a black wire connected 'somewhere' to chassis ground.
Inspect the wiring harnesses and see WHERE the black wires go....maybe a 'butt connector' came off ??
I'd have to see the tractor to help more.
JeepinMaxx
Mar 27, 2018
296
Columbia, CT
Thanks - a bad ground makes sense. I'll at it tomorrow
Mark_BX25D
Bx25D
Jul 19, 2020
1,611
1,141
12.7 running is not good. That's probably not your immediate problem, but running voltage should be 13.8-ish.
Boatman
Kubota L2800, Kubota BX1870
Nov 26, 2016
167
54
Mill Spring, NC, US
I had a very similar issue with my BX1870 a couple years ago. Turns out the wires going to the fuel pump were pinched by the MMM gearbox.
