Kubota BX23--Locked up Front Wheels
9,436
It's easier than you think for water to get in. Fill plug not snug, vent not snug, condensation ,over time,drip by drip water gets in..never leaves unless you do a complete flush and fill. How old is this tractor ? 5-10-15 years ? More than enough time for lots of water to get in !
Curious though, have you disconnected the front drive shaft ?
If yes, do the front wheels move ?
If YES, then not a front axle problem, 'something' in the 4WD selection/gear box is 'bung up'.
If NO, then it probably is ice in the front axle. Only way to remove, LOTS of heat, gently applied. While oil does float on water, if there's enough or it 'flash froze' , the whole axle casing, including diff gears could be frozen.
My hunch is ice in the axle,so heat it up, flush it out, twice, then fill.
If you pick up both front tires and neither turn, it's in the axle not the drive line or drive.
Now if one wheel spins and the other spins in the other direction then the issue is behind the diff, so could be in the drive line or drive.
9,436
And Yes you have a BX23D
They were also labeled BX23MLB, Mower. Loader, Backhoe
Homeowners do all tractor.
Not to be confused with a TLB Tractor, Loader, Backhoe which is a commercial tractor.
Stlouis33
Kubota BX23
Jan 24, 2024
11
Kettle Falls WA
Went out to work on it yesterday and the wheels finally turned! It was super low on lubricant so filled them up and ran it around for a bit....no issues. I have a feeling it was in 4x4 and with the sub temps it locked up but not sure....thanks all for your help!!!
WAS BANNED FOR NSFW PICS
5,157
If you didn't drain it as many people suggested, then you will be paying the price of a full teardown and rebuild with some very expensive parts. Why ask for advice and not follow it, especially when it would cost you nothing to do so? Next time you have a problem, I suggest that you consider asking on Facebook.
BX23-S,57 A-C D-14,
5,831
He 'thinned' out the water that's in the front axle..it'll probably be fine until next Winter's cold snap of 3 days comes, when it happens, we'll all say 'Hay, this sounds familiar'.......
3,270
The British expression "Pennywise and pound foolish" comes to mind at the moment…
5,157
I doubt it will all be OK in the future. Last I heard, iron when it comes in contact with water you get what we commonly call rust.
5,181
Probably will not need to wait until "next" Winter.....
LOTS of Winter remaining yet THIS year!
