Kubota B7100 with B219 Loader and B670 backhoe
5,633
Cool, Cool, Just didn't want you to have a problem when you get it going! ;)
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
353
Homer City, Pa.
Not those bolts, the ones for the gold rod on the valve body for the 3 point ( the slide) adjustment.
danmorea
kubota b7100 loader/backhoe Kubota B2650 loader John Deere x540
Oct 25, 2013
95
15
narrowsburg ny
I reconnect those bolts back, during my search i find more easy to remove piston if i free that rod- i can move the arms bit more to take the piston out clean replace rings
kubotasam
Apr 26, 2010
1,202
128
Alfred Maine
Never tried this myself but I have read about using an air hose to slightly pressurize the differential to get the fluid into the pump if it will not prime itself. If you were to try this make sure you set the air regulator very low or you could blow the seals out of it. I think I remember using 10 psi but you might want to do some research first. I would hate to give you the advice and have you in more of a mess than you are now.
danmorea
Oct 25, 2013
95
15
narrowsburg ny
I replace the pump $415 and now 3 pt hitch works like a dream Old one - slot from gear broke maybe ? clogged filter .All i need was 1 gear -the one that connect to injection pump but they do not sell parts , $250 for used one when they find it Plan to sell my old one in ebay body,rings,etc are in good cond
