Kubota B7001 - hidraulicos
Antonio Chora
Kubota b7001
May 26, 2025
10
Rio Maior - Portugal
olá
o meu kubota b7001 não tem ligação hidráulica traseira, e pretendo adaptar o terceiro ponto hidráulico
já alguém fez essa adaptação?
existe algum esquema prático, ou imagens dessa alteração
obrigado
Moderator Translation:
Hello, my Kubota B7001 doesn't have rear hydraulic linkage, and I intend to adapt a third hydraulic point. Has anyone done this adaptation? Is there a practical diagram or images of this modification? Thank you.
3,118
I think you are trying to add rear remote hydraulics to your tractor.
See this thread starting at post #1 to see a block to replace on the tractor to tap into the tractor’s hydraulic system. Then add as many rear remote valves as needed. The valve must have High Pressure Carry Over (also called Power Beyond) outlet and that is routed back to the block.
See post #16 in this thread for an example of how that block is used on a Kubota L185 to power the rear remote valve for top and tilt.
