kubota B20. I recently installed a new clutch so split the tractor etc. Put in all new hydraulic fluid and filters, new engine oil and filter. 1st time working it the tractor seemed to get hot, water temp was ok, and then the engine bogged down so I shut it off. After a little research I checked the engine oil and it was overfull. The hydraulic oil was low. The engine oil does not smell like diesel. What would cause the hyd fluid to go into the engine? Could I have connected some hydraulic line wrong? All hydraulics seem to be working. I changed the engine oil so I could put the tractor into my shop. The hyd oil seemed to get hot for just running it 2 minutes. Thanks, Cloud
