Kubota B20 Hydraulic filter housing question
Jmshields
S.C
Was hoping somebody had prior experince with where the hydraulic filter housing tube enteres the reservior pipe on the frame of the tractor circled in pic.Is the pipe a tight fit into the reservior or is there a seal there?Mine appears to be dripping fluid.Thanks
5,779
curious, found the diagram,zooooomed it up.
There appears to be TWO O-rings, #150, probably need to replace BOTH of them.
Looks like you have to remove a LOT of 'plumbing' to get to them,so have a box of bandaids close by !!
I like to print off 2 copies of the diagram,zoomed up of course. Use magnets to hold them close by .
Jmshields
S.C
Wow you found it.Thank you so much.Kubota oil is more expensive then a bar of gold these days.I read a coiuple of threads where they couldn't figure out why their hydraulic filter was still leaking and I bet it was those orings.This will be the 4th time I will have had to remove the fluid as I had to flush all the lines.Not looking forward to removing those lines going to the front pump.Thank you again
9,190
That pipe haas 2 O-rings on it.
