kubota b-1700 won't start, turn over, with key, but starts when solenoid is jumped.
vt.shane
kubota b-1700
Aug 10, 2023
vermont
I READ OLD FOCRUM POSTS AND FOUND OUT THERE ARE 3 SAFETY SWITCHES THAT NEED TO BE CLOSED TO ENABLE POWER FROM KEY . CAN SOMEONE TELL ME WHERE THEY ARE LOCATED ON B-1700 AND SHOULD I MEASURE FOR CONTIUITY, OR SOMEHOW MEASURE 12 V. I HAVE ONLY OWNED TRACTOR A SHORT TIME. THE ORIGINAL KEY SWITCH PHYSICALLY TURNED HARD, SO I REPLACED WORN OUT SWITCH WITH A BRAND NEW SWITCH, WHICH WORKS FINE. I HAVE A WSM REPAIR MANUAL FOR THE TRACTOR, BUT THERE ARE NOT MANY DIAGRAMS. I WOULD GREATLY APPRECIATE HELP FROM ANYONE!!!
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
I can't tell you the physical locations on your tractor but the PTO needs to be off, you need to be sitting in the seat, and you need to depress the clutch. It may have a neutral switch as well.
Ktrim
B2400, lA352 loader,3pth quick hitch/z122r zero turn/restored 52 farmall super a
Dec 23, 2020
426
344
Nazareth Pa
Do you get anything at all? Click or just dead key
6,430
Which model do you have?
FYI: Typing all caps is considered yelling.
vt.shane
kubota b-1700
Aug 10, 2023
vermont
thanks for help. I found 3 switches. Pto, hydro neutral, and clutch switch. The neutral switch is under the seat, and seemed to move kinda hard. I oiled the mechaniical linkage and it moved easier. Next I hooked meter to unhooked solenoid wire. I read 10.5 volts to ground, when I turned new key switch to start position. Next I reattached solenoid wire, sat my ancient arse on the seat, depressed clutch and was thrilled when tractor started with key. thank you for help and support. vt.shane
