Kubota 2920 hydraulic leak
4,999
Rusty - - Umm, I don't think it's possible for a rear tire to leak hydraulic fluid.....
I do see you have a B2920...
Better description and pictures will help.
You either have:
(1) a rear axle seal leaking hydraulic fluid onto the tire, or
(2) a tire leaking whatever fluid has been used to fill the tire for weight (we call that "ballast"). That's not normally hydraulic fluid. It's often Calcium fluid, beet juice (Rimguard), or windshield washer fluid.
More info would be helpful.
Rusty1959
Kubota tractor b2920
Jan 24, 2021
Wisconsin
Rear axle seal leaking hydraulic fluid onto tire. How hard a fix is this? Bought in 2013. 275 hours on tractor
whitetiger
Nov 20, 2011
2,905
1,373
Kansas City, KS
You have to remove the ROPS, then the axle housing, and disassemble the axle. See PDF below.
Rusty1959
Jan 24, 2021
Wisconsin
Rear axle seal leaking hydraulic fluid onto tire. How hard a fix it this
You either have:
[/QUOTE
Leaking hydraulic fluid out of rear tire.
Leaking on left rear wheel
4,999
Rusty - if you look just above your last message, there is another from member whitetiger. He has details on what needs to come apart, and a parts diagram of the axle area your working on.
I have not done this repair on a Kubota tractor, but I'm sure whitetiger has done many.
Like I suggested in a couple other threads you posted on, a workshop manual (WSM) for your tractor will probably help you greatly in doing the repair.
