You have to remove the ROPS, then the axle housing, and disassemble the axle. See PDF below.Rear axle seal leaking hydraulic fluid onto tire. How hard a fix is this? Bought in 2013. 275 hours on tractor
Rusty - - Umm, I don't think it's possible for a rear tire to leak hydraulic fluid.....
I do see you have a B2920...
Better description and pictures will help.
You either have:
(1) a rear axle seal leaking hydraulic fluid onto the tire, or
(2) a tire leaking whatever fluid has been used to fill the tire for weight (we call that "ballast"). That's not normally hydraulic fluid. It's often Calcium fluid, beet juice (Rimguard), or windshield washer fluid.
More info would be helpful.
[/QUOTE
Leaking on left rear wheelLeaking hydraulic fluid out of rear tire.
Rusty - if you look just above your last message, there is another from member whitetiger. He has details on what needs to come apart, and a parts diagram of the axle area your working on.Rear axle seal leaking hydraulic fluid onto tire. How hard a fix it this
