The large piece of steel inside the tank probably didnt come from inside the system.
This is what occurred to me
Yes adding the drain is now on my list to add. I have the WSM, it's helpful but not comprehensive.The mesh in the neck is supposed to keep 'stuff' from getting INTO the tank.Unless it's fastened somehow, you have no idea when it was installed. Since there were 'items' bigger than the holes in that screen on the bottom of the tank, it wasn't doing it's job.
I'd have thought there would be a 'drain port' on the tank, maybe on the side ? If not, I'd add one. Remove the tank,clean tank, drill hole, weld 'pipe flange' piece on. If NO chance it can be damaged, put on bottom, otherwise on a side wall. You can buy pipe plugs with magnets on them or make your own.
If possible find parts drawings of the unit (maybe the WSM ?) to see how it was built. Unlikely to need to modify the unit though.
Curious just how old is the beastie ? Two of my tractors had 1/4 - 1/2" of 'gunk' in their hydraulic sumps yet hydraulics worked great.
Rich, that's some sound advice. I'm sure that the pump is a likely culprit for the contamination.After the cylinders are out for repair I would replace the pump. Those little shavings are from it more than likely. Tring to rebuild it may not be the best the since the heat treated surfaces have been damaged and the soft steel core will wear much quicker and contaminate the system and ruin the new seals in the cylinders.
The pressure relief should also be removed, cleaned and set to correct pressure. Controls should be cleaned and new seals done.
Enjoying your progress reports!On the age thing, this backhoe was for models produced between 1981 and 1990. so we have an age range of 42 to 33 years in service!
All cylinders are now removed, along with the pump.
Slew cyclinders were straight forward, undo the 4 bolts and remove the caps, then lift and wiggle the ram out the back.
The next challenge was the leg rams, the obvious issue is that I can't simply extend them down as there isnt enough clearance, Titling the whole frame worked a treat and allowed the legs to slide out... it wasn't that easy though! It tooks lots of hammering to persuade the left leg to come out, the right leg needed even more work, including defrosting, but I got there and now have all the cylinders out and ready for the shop after christmas.
And the sweet relief of getting it out View attachment 118625
The leg was full of liquid, no doubt a mix of oil and water which had frozen and prevented the movement, not help by the bulging of the leg post, no longer a flat slight, but bulging out and causing hard contact. this will be rectified before refitting.
7 cylinders out
Pump removed to be stripped on the bench
Next steps
Valve removal to go to the hydraulic shop.
Hoses - swap the oldest ones for new, change the pump sution hose for a hydraulic hose.
Tank, remove, clean, add boss for magnetic sump stud, add oil level gauge.
Ivory Snow FlakesInteresting project.
Hope it works out well for you!
From Florida: What is that white stuff on the ground?
My mother always bought "Ivory Snow Flakes".Ivory Snow Flakes
THAT wobble....is certainly not good!
Hopefully you can see the video of the wobble the PTO input has.
