Kitchen and Bath Faucet Manufacturers - Your Favorite?
Donystoy
Dec 10, 2013
683
309
Binbrook, Ontario
I also agree with the Moen crowd. I did install American Standard in a bathroom that I renovated a few years ago since my wife preferred the style. They were not the solder type and one fitting split a day after I installed the male fitting into it. Another split a year later. I ended up installing hose clamps over all the fittings for a bit of insurance. They have inner and outer threads that just do not have enough material in the center. In all the years in the A/C trade I seldom experienced this.
And yes 95 pounds seems way too high. I run our pressure system at max of 60 pounds and use a water softener. Even local city water is at 75 pounds max. I would think that insurance companies would have an issue with high water pressures especially if using pex. Our insurance company charges higher rates if house has any pex in it for the main plumbing system.
SidecarFlip
Banned
562
My rentals are all on the same aquifier we are so they are all as bad as ours is. I bet I've replaced about 30 faucets so far. The cheapo plastic ones always last longer, but none are forever. What I really go through is aerators. The calcium destroys them. Great to live in rural America.
SidecarFlip
Banned
562
Interesting. All my rentals are in PEX as well as our home. Never been an issue but then I limit my pressure to a maximum of 55-60 psi. Our carrier don't care what type of plumbing it is. never have asked.
9,460
Watch this and you'll be surprised.
That's the first I've ever heard of an insurance company charging more for PEX in a home. :unsure:
I have all PEx plumbing and Pex for the hydronics system.
SidecarFlip
Banned
562
Interesting Wolfman but no residential system will ever see static pressures over 100 psi so long as the limit switches are working correctly and I don't believe a submersible pump will push more than 150 psi anyway. I won't use 'Sharkbite' fittings, All mine are bad crimp.
Tornado
792
255
usa
Moen all in my house, and some of them are really old faucets and such and still work just fine. My mother recently upgraded her kitchen and put in a really nice moen kitchen faucet, one of the expensive fancy ones and she loves it. Its been in place for a year now.
Donystoy
Dec 10, 2013
683
309
Binbrook, Ontario
I think the insurance companies are still thinking it is like the grey plastic piping that was the first attempt at replacing copper many years ago. I remember seeing write-ups in plumbing magazines in the 80's regarding the issue. The pipe itself was fine but the fittings had a habit of opening up inside walls.
Good luck with your house build and stay safe.
