King Kutter scoop?
mike paulson
229
24
ulster, NY
Hey guys I have a the larger sized King Kutter dirt scoop. Im in the process of buying a b2620 and was wondering if this will fit my new tractor? If someone with a B2620 or B2920 could give me max spacing between 3pt lift arms that would be great. I checked everywhere for specs and couldn't find anything on the B2620 3pt spacing....
1,415
Is this what you were talking about? How is this implement used?
These scoops are also called the "poor man's loader".
They are pulled behind to take up some dirt, lifted, then dumped in another site. Some can be turned backwards so you can back into the area to scoop from.
In answer to the will this fit my tractor question - what category 3 point is the implement and what category 3 point is the tractor? If they are the same then they will fit.
mike paulson
229
24
ulster, NY
they make a great ballast box too, I put spackle buckets filled with concrete in them about 150 lbs a piece, also mostly used to back into piles.
