King Kutter Middle Buster and Sub-Soiler Question
LMTractorGuy
L2501HST, LA525, RCR1260, BB1260, Titan 48" SS Forks, Stump Bucket
Sep 20, 2016
70
SC
I considered the King Kutter XB which is the combination middle buster/subsoiler. It is not as heavy as the King Kutter MB or the Sub-soiler SUB which are separate units. Are both the MB and SUB units the same dimensions? If so I could remove the MB plow and replace with a homemade sub-soiler blade. Thanks for the help.
8,164
If you look at the pictures close enough you'll get your answer, the MB is shorter than the SUB. ;)
LMTractorGuy
Sep 20, 2016
70
SC
Wolfman, I thought the same thing. I have emailed the King Kutter to see if they can send me detailed dimensions.
scdeerslayer
MX5200DT
May 23, 2016
434
SC
Probably more trouble than it's worth. You'll likely have to cut off the plow bolts and install new ones each time you switch unless it doesn't see much use between swaps.
6,264
Might keep an eye on CL. You'll find them there, then you won't have to modify either on.
I just picked up a sub-soiler from CL. Brand new, still had the bar code on it. Never been in dirt, $100. It's too cold out or I would go get a picture for you!
