Key Stop Timer
torchlaker
L2250, L175
Oct 8, 2017
Eastport, MI
I've run into a problem while troubleshooting the electrical on my L2250. The Key Stop Solenoid is not functioning. So I pull out my trusty WSM for the wiring schematic. I have a Key Stop Timer relay with only 3 terminals, while the WSM clearly shows 4 terminals. It shows troubleshooting steps as well as wiring diagram. I've looked for alternate schematics with no luck. Hopefully someone here can shed a little light on this issue.
jaxs
B1750HST
Jun 22, 2023
756
570
There's a bunch of ozone and cloud of dust between me and your tractor but I might try troubleshooting with the idea relay might use it's mounting to chassis of tractor as ground (4th wire in schematic). How to go about that? Remove relay, sand areas where relay and chassis touch,remount and tighten securely.
whitetiger
Nov 20, 2011
2,942
1,399
Kansas City, KS
What are the colors of the 3 wires?
torchlaker
L2250, L175
Oct 8, 2017
Eastport, MI
Thanks for the quick reply. Unfortunately the enclosure is all plastic.
The colors are black, red and blue. I've attached a pic. No markings on the relay at all. Also I checked another nearby l2250 and it has the same 3 wire connection. Seems to rule out somebody switching out the relay.
5,047
hmm, 'historically', in some circles, Black would be ground, Red would be +12 from somewhere, and Blue would go to whatever needed 'switched' power.
What's interesting to me is that the white connector on the harness appears to have 4 'poles', and the 'adapter cable only has 3.
whitetiger
Nov 20, 2011
2,942
1,399
Kansas City, KS
See what color the three wires are in the connector on the wiring harness that this box plugs into. I suspect they will be White, Green, and Black.
I suspect that is the Flasher unit.
The timer should have a 4-wire connector on the harness which plugs directly into it. It should also have a metal tab on its top that bolts to the frame behind the dash.
Dustball
2016 B2650HSDC
Sep 15, 2023
312
188
Hudson, WI
It sure looks like that you're looking at the hazard unit?
jaxs
B1750HST
Jun 22, 2023
756
570
Indeed enclosure is all plastic but mounting tab is metal. Must I say "Remove relay,sand areas where relay TAB and chassis touch,remount and tighten securely"?
whitetiger
Nov 20, 2011
2,942
1,399
Kansas City, KS
The metal tab just snaps onto the plastic body, it is not a ground.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,828
1,544
WestTn/NoMs
I think your key stop timer relay should look like this
