Good morning!
Over the last year or so I have been considering buying a tractor. At first considered older used tractors but found it hard to find one equipped with a FEL. With the way tractors hold value, I believe it’s a better choice for me to buy new. For reference, have never owned a tractor.
Upon starting my search I was originally dead set on buying a John Deere 1025R. Since then I have flip flopped a few times. Below is the main part of what I will be using the tractor for:
1. Clearing very hilly/steep land that is currently wooded. Grading (at least assisting with grading) same area with fill. 2 acres total.
2. Maintaining approx 1/4 mile of dirt road and driveway.
3. Once above said property is less wooded planning on running a flail or rotary mower to keep brush down.
4. Looking at running rear PTO implements such as stump grinders and chippers.
Now that you have a better picture, I switched my thinking from the 1025R to a LX2610SU as I felt I got more tractor for the buck due to me feeling I have no use and will not use a mid mount PTO. My concern however is that going with the larger tractor I will be making it more risky for myself on very steep terrain, though I don’t know that to be fact. I had a salesman that priced out the LX tell me that it would actually be more stable with loaded tires because of the width vs something like a BX. The upgrade from a subcompact to compact in my mind makes sense for FEL lifting and what seems to be higher rear PTO output.
I am open to pretty much any machine, but have really looked at the BX, LX SU, and L in the 25hp configurations.
Would I regret the larger tractor on the land I will be working?
As far as pricing goes, typically what is the spread from BX (I’m guessing for comparisons sake that a 26hp marked BX would be the most comparable) vs an LX SU model or the L2501?
Based on your experience what tractor would you choose and why?
