Kabota L 3901 Help
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
Interesting. Where's it getting 110 volts? More importantly, why, on a 12v system? 12v will power an injector without any problem.
Agreed. The ECU clearly isn't happy, so it's not letting anybody have a good time. I mentioned it really as a matter of curiosity.
I understand and you are right. I dont have a way to load it right now. Ill need another tractor to do so.
So you have the only tractor in Uvalde Texas?
sheepfarmer
Nov 14, 2014
4,438
678
MidMichigan
My guess is that he has the only tractor available to him.
We don't always know another person's complete circumstances.
Mark I understand that was harsh, but the cost of renting, borrowing, or hiring someone to haul his tractor is going to be far less than replacing some of the parts. As you can see from some of the above posts the injectors and ecu cannot be replaced without the Kubota software and hardware to enter in the new parameters. That information is in a wsm, but without it you and he are shooting in the dark as to how far you can safely go. Many people hate the new tractors because of their dependence on company owned stuff. Read the lengthy threads about John Deere right to repair.
Mark_BX25D
Bx25D
Jul 19, 2020
2,101
1,606
This problem is either the ECU is fried, OR it's not getting the right inputs. (Or both!).
There's nothing unsafe about taking measurements. There's also nothing unsafe about providing ground signals downstream of the ECU to verify those components. If it were jumping 12v in there, yes, there is a risk with that, but there is also a way to eliminate the risk (disconnect the ECU from that terminal). But simply grounding a relay terminal that is connected to an ECU that would ground that same terminal is not going to bother the ECU at all. So, there's nothing unsafe here. He's not going to fry anything. But, we're past that stage anyway, since we know the ECU is not grounding that terminal. That leaves verifying the inputs.
He can safely troubleshoot the inputs, and there is unlikely to be anything there that he can't fix himself. So, if he finds a problem with an input (once he knows what they are) and it's something simple like a bad switch or sensor, it's a big win.
If the inputs all check out correctly, we'll know it's the ECU, and it's dealer time. I'm sure at that point he'll find a way to cross that bridge.
