Check the RED kill button on the lower left side of the operators' console, it should be pushed in.
The relay for your fuel shut-off solenoid is behind the RH side skirt.
There is a technical service bulletin for this issue. Make sure your new solenoid has the white paint mark on it or it will probably fail.
TSB-2023-049-E-R3 - K, KX, SCL, U-Series; Engine Stop Solenoid Failure
May 19, 2024•Knowledge
Article Number
000007119
Article Record Type
Bulletins
Last Published Date
5/19/2024, 4:00 PM
Language
English
Title
Bulletin Type
Fix as Fail extension
Description
Repairs described in this bulletin may be made only in the event of a failure.
Product Line
Subject
Solution
If the installed engine stop solenoid fails, replace it with the improved engine stop solenoid below per the procedure on page 3 of the attached TSB.
Note: Incorrect installation or damage to the plunger rod of the new stop solenoid will prevent the engine from shutting down. Remove and inspect the new stop solenoid if this occurs, then carefully reinstall.
Warranty
This bulletin applies in the event of a failure and does not constitute warranty authorization to update units without a defect in material or workmanship.
Source Bulletin Number
CM-23-048-04
Products
K008-5, KX018-4, SCL1000, U10-5, U17
URL Name
TSB-2023-049-E-K-SCL-U-Series-Engine-Stop-Solenoid-Failure
Serial Numbers Affected: Model Serial Numbers Model Serial Numbers
K008-5 10001 to 11358
KX018-4 46312 to 48132
SCL1000 11280 to 14933
U10-5 10001 to 11249
U17 53750 to 60039
