JD 7130 engine failure at 4600 hours
Shadow_storm56
Lawn mower
Oct 22, 2020
524
62
Get some John Deere break in oil. Change the oil and filter. And fill to capacity with the break in oil. Then put that baby under an 80% load. It will re-seat the rings.
Honestly, at only 4,000 hours, I would be ruling out all the stupid simple stuff first before jumping to an engine issue.
That engines just getting broken in. The only time I've run into head issues with JD 6 cylinders is if they've been hydrolocked or over heated really badly.
Ive never had to have a ring job done on one with 4,000 hours.
I've replaced turbos on them at 4,000 hours.
Ive had to replace the rubber sleeves on the intercooler lines do to loss of boost pressure.
I once had to pull on intercooler and take it to a radiator shop and have it repaired because it had a hole in it.
I thought the intercooler could have been why the bubble issue exists but the issue is still there even if the intercooler is out of the circuit.
9,116
I missed that. If your getting bubbles, then you got bigger issues than your boost. Sound like a head gasket
Shadow_storm56
Lawn mower
Oct 22, 2020
524
62
Only thing I had to use like a dyno in the meantime was a water pump. Just to test the blowby, definitely there but I have seen worse and definitely not enough to effect boost.
Shadow_storm56
Lawn mower
Oct 22, 2020
524
62
So the engine is gone unfortunately, pretty sure when they said the first time the bubbles was nothing that it lead to overheating in spots or the intercooler was not getting good flow and thus the intake air was too hot.
No idea it's got big blowby, inconsistent compression and low power. Plus a bad turbo.
No one can say why this happened either.
I'm looking at an m6-131-1 but they are all so short and I really liked the long from whare we are on a big hill
Shadow_storm56
Lawn mower
Oct 22, 2020
524
62
This got so much more interesting! We were talking to different dealers and such.... Basically Engine just needs a head gasket and deere made up an insane cost and said it needed an engine so we would buy new..... soooo me deere is now at the kubota dealer getting fixed lol.
BAP
Dec 31, 2012
3,125
1,259
So when you refer to Deere telling you that you needed a new motor, were you actually told that by an official company representative or just your dealer? Your dealer is not John Deere, they are just an agent who has no authority, but they can overcharge you by making up repairs needed to be done. It can happen with any brand and color of tractor out there.
Shadow_storm56
Lawn mower
Oct 22, 2020
524
62
Green Diamond they are called here.... same ones that when we had a Lemon 5083En that fell apart were like "That sucks we can sell you new" lasted 1700 hours.
Meanwhile I have a 2350 and 2355 that have 10K hours and running great.
I'm not sure how you would contact John deere themselves in canada other than Email
