Is Top and Tilt Worth It?
JChamp
L2501, Loader, Grapple Claw, Forks and Box Blade
Oct 24, 2023
Atlanta, GA
I apologize if this question has been covered. I used the search feature and didn’t find an answer.
I’m getting a new L2501 for use around our new 17.25 acres. The driveway isn’t paved (yet) so I’m debating between a Box Blade and a Land Plane. If I go with the Box Blade I’m thinking the Top and Tilt is a must for a newb like me. If I go with the Land Plane it seems a little more dummy proof. My question is, is there value for other 3 point implements that I may end up getting to help justify the cost of adding it, or is it just flat out worth it to add for the on the fly adjustability with a Box Blade or Land Plane?
The other implements that I’m getting are:
Loader & Bucket (with tooth bar)
Grapple Claw (with 3rd function)
Forks
I can envision adding a tiller, maybe a brush hog or mower and maybe a post hole digger at some point. The primary use of the tractor will be maintaining our driveway, trails in the woods and other chores around our house, but I’m not ruling out an occasional side-job at some point.
Thanks in advance for your thoughts.
mcmxi
6,335
NW Montana
Forks
Top & Tilt is 150% worth it. I have the Land Pride/Kubota kits on both of my tractors and would not be without them. You can get better kits it seems that will allow tilting/rotating the implement clockwise and anticlockwise. The Kubota kits appear to only rotate the implement one way. The top link cylinders are fine though. Also, you can find cylinders that have one-way or anti drain features that will prevent the oil from leaving the cylinder, which causes the implement to sag one way or the other over time. Whether or not that's an issue for you depends on your tolerance of implement sag. :LOL:
Sometimes you can run into an issue with only 3 rear remote valve sets as I have on my tractors. When I hook up the rear snow blower with hydraulic chute rotation and deflection, or the Del Morino hydraulic offset flail mower I have to give up either the top link or side link cylinder function. Not a big deal for those implements but it's something to think about.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,185
877
PNW-WA
Top and Tilt are worth it IMO. Not only for a Box Blade, also for a Back Blade. The "Top" can be very useful when connecting all implements in general.
UnEasyRider
L3302 LA 526 loader, Box Scraper, Grappler, Forks, Rotary mower, Big Tool Rack.
Apr 14, 2023
136
68
Florida
What is Top n Tilt. Musta missed something at the dealer!
MtnViewRanch
796
233
Lakeside Ca.
Here is a T&T set on a larger tractor, but gives you an idea for your own.
Hydraulicly tilts the implement forward-back wards and on some sets, both left & right. Some sets only to the right.
If you are going to grade much or have constant driveway maintenance, a very nice feature to have.
UnEasyRider
Apr 14, 2023
136
68
Florida
Thank you! Maybe next tractor as I don't have all the hydraulics in the back (nor the money in the bank at the moment) and would rather get everything OEM.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
610
530
Indiana
Can you get a float modes with top and tilt? It would be handy for bushhogging trails on this place.
4,244
Yes. You just need a rear remote with float detent and whatever cylinder you want to float can’t have a check valve. One of my three rear remotes has a float detent so I can float the toplink or sidelink. If I had two rear remotes with float, I could float them both at the same time.
mcmxi
6,335
NW Montana
I have one float detent valve on both tractors, and for example, use it for the snow blower tilt function with the idea that the blower will follow the terrain a little better on off-camber transitions. I give up the top hydraulic link for snow removal, but do the opposite for the Del Morino flail mower. I want the hydraulic top link for that application and give up the tilt cylinder. I'm not interested (yet) in adding more valves by adding some form of manifold with electric over hydraulic switches.
MtnViewRanch
796
233
Lakeside Ca.
Land Pride is the perfect example of an under-engineered top & tilt system. :oops:
The cylinder stroke should be in the middle of the stroke when the implement is level front-back and side-side. Don't get me wrong, it's better than nothing, but far from being the premium set up.
Soopitup
BX23S
Oct 25, 2018
341
159
New England
What would be an example of a premuim setup?
NorthwoodsLife
Oct 15, 2021
1,055
1,003
Wisconsin
Top and Tilt IS worth it if you have lots of money.
It's not worth it if you can't buy your kid new shoes because your too F'n lazy to get off your ass and turn a couple turnbuckles.
2,813
