is this the remote or the 3rd function valve?
eichhoma
MX6000
Jul 6, 2023
25
Missouri
Hello, This is on my MX6000 on the right side next to the bucket control stick... It looks there was a couple nuts that backed off and the box is hanging int here. Is that the remote or just a valve? Anyone know what size nuts those are that should hold that on? SAE or MM? I was surprised they actually backed off and that my local Kubota dealer could not tell me. Thanks.
11,161
It's most likely the third function, doesn't look like a valve, looks just like a connection block?
Doesn't really matter.
Judging by the length of the bolts, looks like your also missing a plate that would a have gone on the back side of the bracket for the bolts to attach to.
As far as the bolt goes look at the head of the bolt, that will tell you what it is.
whitetiger
Nov 20, 2011
3,746
2,160
Kansas City, KS
They are SAE, 5/16" if I remember correctly. They should have had a nut and lock washer on each bolt. The bolts go through the valve; there are no other plates.
7,677
When you put it back together apply a coating of your wife's least favorite nail polish and let it set overnight. Keeps the nut from working loose and doesn't restrict removal if needed.
