Is this a concern or normal
Sniners66
Svl95-2s
Aug 13, 2024
14
Gadsden
I own a 2017 SVL95-2s, once engine is started a yellow triangle on dashboard comes on and is blinking and there is an audible beep for maybe 30secs to a minute. There are no error codes on machine. What is this flashing/beeping signaling?
2,720
Everything I read says there should be a code that is displayed.
Or "see the dealer"
Sorry = not a lot of help!
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
147
148
According to the PDF manual I pulled up it says:
WARNING LAMP:
The warning lamp is used to indicate broken wire, short-circuit and other problems.
The lamp lights up to warn you of a detection of broken or short-circuited hydraulic lock/unlock solenoid, AUX port variable switch and other elements.
If the warning lamp lights up, consult your local Kubota dealer immediately.
5,521
so the 'computer' KNOWS there's 'something' wrong BUT doesn't TELL the operator exactly WHAT is wrong.....
sure wish these 'engineers' would OPERATE what they designed for a week or two in the real world....
Bmyers
May 27, 2019
3,387
4,118
Southern Illinois
Sounds a lot like a wife to me......tells you everything but what you need to know. :p
whitetiger
Nov 20, 2011
3,065
1,510
Kansas City, KS
If you try to move the machine before it stops, you will find the hydrostat slow or sluggish. This warning tells you that the traction drive is derated until all parameters are met.
There is no cause for concern.
8,179
Like a warm up delay?
mikester
M59 TLB
Oct 21, 2017
3,758
2,316
www.divergentstuff.ca
I think the engineers do what the bean counters and sales people tell them to do.
That's why my Toyota only allows 4 TMPS sensors in the computer and wants me to go to the dealership and pay $50 to reprogram the TPMS when I swap winter/summer tires. No thank you.
Sniners66
Svl95-2s
Aug 13, 2024
14
Gadsden
Thanks. I was hoping that was the issue. I’ve never moved it until it stopped beeping and went out. Wouldn’t anyway because I like to let it run for at least 5 minutes to warm up.
Gov
SVL95-2s
Aug 25, 2021
Mississippi
If it's when you first start up as you state, it's a warning to let your machine get to operating temperature before engaging hydraulics. It normally goes out within a minute.
