Is this a concern or normal
Sniners66
Svl95-2s
Aug 13, 2024
Gadsden
I own a 2017 SVL95-2s, once engine is started a yellow triangle on dashboard comes on and is blinking and there is an audible beep for maybe 30secs to a minute. There are no error codes on machine. What is this flashing/beeping signaling?
2,600
Everything I read says there should be a code that is displayed.
Or "see the dealer"
Sorry = not a lot of help!
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
143
147
According to the PDF manual I pulled up it says:
WARNING LAMP:
The warning lamp is used to indicate broken wire, short-circuit and other problems.
The lamp lights up to warn you of a detection of broken or short-circuited hydraulic lock/unlock solenoid, AUX port variable switch and other elements.
If the warning lamp lights up, consult your local Kubota dealer immediately.
5,191
so the 'computer' KNOWS there's 'something' wrong BUT doesn't TELL the operator exactly WHAT is wrong.....
sure wish these 'engineers' would OPERATE what they designed for a week or two in the real world....
Bmyers
May 27, 2019
3,320
3,911
Southern Illinois
Sounds a lot like a wife to me......tells you everything but what you need to know. :p
