Is there a backhoe that fits B6200
tractorslave
B 6200 hst 4wd
Apr 16, 2012
54
Western MASS
I have found a Kubota brand back hoe with the hydraulic pump and controls.
It comes with sub frame arms and a seat.
I am concerned about overloading my B6200.
Can you guys tell me if there was ever one made for it.
If so what size was it?
The seller has no numbers on his.
Thanks for anything you can give me.
Yes, I ran the search box on this topic and came up with nil.
Orange is rapidly becoming my favorite color!
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
9
Richmond Va
So far judging by the picutres it seems a tad too large. Anyidea the size of the boom on the hoe you have in question?
PeterA
B6200 HST 4WD @ SIMS cab, Kubota 1630 FEL, rototiller & plough
Dec 17, 2010
38
St. John's Newfoundland
Did you get a response to your question about the backhoe? I'm interested in getting one for my B6200, so would benefit from your experience. Thanks. Peter
3,099
I can't help with what model that is, but it's not a B670, which was fitted to the B6100/B7100 series.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
Leafy England....
Yes it will fit a 6200 but you may need to double check the subframe mounting points.
As far as size is concerned , its fine, the pic does make it look bigger than it really is.
I have a parts and owner manual for the same unit in my desk somewhere, bought it on ebay a while ago just in case it came in handy.
this backhoe will also also fit B6001/6100, 7001/7100 and maybe afew others but subframe mounting holes may vary on others.
I would say 6001/6100 would be the smallest fitment, i'll have a rummage through my kubota files to find the relavant docs if thats any use.
rob
Rob
Nov 22, 2009
679
Leafy England....
Just been in the files, according to my official owners manual, it looks to be a Kubota 130 backhoe model, (KB130)
digging depth: 6ft , reach: 9' 2" , arc of swing 135 deg etc
buckets, 8" , 13" and 16" widths.
operatring pressure: 1800 psi, flow rate @1000rpm at PTO is 4 gpm, system capacity 4 gallons.
you may find it labelled as a differing model in the US, but in my manual is says worldwide spec.
The K629 backhoe is pretty well the same unit also.
your backhoe is missing the hand rail that bolts onto the backhoe chassis though, may have been damaged and taken off..
hope that helps.
PeterA
Dec 17, 2010
38
That's helpful, Rob. I just have to figure out where to pick up one here in eastern Canada. Thanks.
