is my tractor now scrap metal?
pejepscot
Kubota L260
Aug 12, 2014
60
Topsham, ME
While moving snow banks with my old 1975 L260 this weekend there was a sudden change of engine sound and significant loss of power. Now it will barely start and run.
Upon inspection I opened the small side cover on my injector pump and found that a plunger spring broke and one (of my two) injector delivery mechanisms was kaput.
This tractor has the Z1300 engine and a Nippondenso 090000 3582 injector pump. Parts for this engine and pump are nonexistant and a decent manual is not to be had either. I have no idea how to remove/reinstall the injector pump and ensure that the timing will be OK. Even if I were to remove the pump, then what?
I am heartbroken as I love this tractor - it is a perfect size for me. Bringing it to a Kubota dealer is not likely to help as they have no idea how to work on this old stuff.
Help, I need some sage advice.
coachgeo
Nov 16, 2012
2,460
32
Southern OH
With scarcity of parts.. I wonder........ has anyone ever retrofitted an older 2cyl model like this one with a China Yanmar Clone, Hatz orr?
Were these 2cyl tractors blocks also used as structural members like some of the 3cyl ones were? If so can see some additional issues with transplants but if not then.... why not a transplant?
5,357
pejepscot
Kubota L260
Aug 12, 2014
60
Topsham, ME
Hi Wolfman!
Thanks for the ray of hope. I saw those downloadable manuals before, but was hesitant because I thought they were those crappy I&T "manuals" which are all but useless.
Anyhow I followed your direction and got that manual and it is quite good! Thanks!
It said in the manual that the pump assembly slides out and employs a MASTER SPLINE. I hope a "master spline" is one in which there is only one way to re-engage the male and female parts. Is this true?? If so I will feel confidant that I can get the pump back in place with correct timing.
Thanks, Ren
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
That is , indeed what a master spline is. it has one thick spline, and the rest are thin, so it only goes back together one way...:D
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,145
941
Williamstown Ontario Canada
It never hurts to visit a diesel repair shop. A place that services injection pumps and injectors. Often the injection pumps are used on other engines and can be fixed.
Dave M7040
pejepscot
Kubota L260
Aug 12, 2014
60
Topsham, ME
Dave M7040
Yes Dave, I called Atlantic Fuel Injection (about 20 miles away) and they didn't say they could fix it, but they didn't say they couldn't either. :)
I think I'll pull it off and drop it by the shop and see what they think once they see it.
If it would just stop snowing long enough to allow me to get out of the plow truck and into the shop....
pejepscot
Kubota L260
Aug 12, 2014
60
Topsham, ME
I pulled the pump off tonight. It doesn't appear to have a one-way master spline. It has a symmetrical spline with an alignment mark. It will be very difficult to see the marks when reassembling but she's apart now so I'll have to do it somehow. I'm going to bring the pump to the injector shop tomorrow if I can ...
dmb
Jan 30, 2015
Lakewood Ca,
just start at tdc, set timing marks up ''a little paint on the spline helps'' install the pump. and now is the time to adjust the valves too, if i can do it anyone can. it makes me feel better if i do it myself and i cant afford to have someone do it for me! dennis
pejepscot
Kubota L260
Aug 12, 2014
60
Topsham, ME
UPDATE The injector pump and injectors are at Atlantic Fuel Injector Service awaiting rebuild. They called and advised me that all parts are available and on order. Everything should come back to me in like new condition, but it will devastate a $1000 bill...OUCH!
Diydave
Oct 31, 2013
1,635
Gambrills, MD USA
Seems to be about the going rate for a pump rebuild, AFAIK...:eek:
Apogee
Jan 22, 2012
518
Tacoma, WA
pejepscot
Kubota L260
Aug 12, 2014
60
Topsham, ME
Steve, the fellow there who started working on in injectors and pumps in 1979 strongly encouraged me to bring in the injectors, too. I really like this old horse so I decided to invest the $$ needed to make it right. Fingers crossed that it ends up worth it....
Apogee
Jan 22, 2012
518
Tacoma, WA
Pejepscot,
One other thought that comes to mind since you're working on the tractor anyway is the steering box. The steering boxes are a Kubota weak point on the older units. You might consider taking this opportunity to drain and refill it if you haven't recently. They are often overlooked and it results in the box getting damaged if they run dry or if moisture gets in.
Due to boxes leaking as they wear, I now deviate from the factory and pack mine with Shell Avania EP00 grease (Kubota/Land Pride PN 821-045-C). However, no matter what you use, as long as it's being maintained it will live a long time.
I don't know if your particular unit has a drain plug or not. Often they don't and it's a pain to empty them out. But, in the end it's usually worth it because it's an overlooked maintenance point. Lots of times there ends up being water in the box if the tractor ever spent considerable time outside.
Here's an awesome series but together by Service Dept Vic for more info on what happens and how to rebuild if damaged:
http://www.orangetractortalks.com/2009/02/diagnosing-and-preventing-steering-box-failure/
http://www.orangetractortalks.com/2010/01/how-to-repair-a-steering-box-part-1/
http://www.orangetractortalks.com/2010/09/how-to-repair-a-steering-box-part-2/
Food for thought.
Steve
pejepscot
Kubota L260
Aug 12, 2014
60
Topsham, ME
Yup, you are right, the steering box was toast on this L260 when I got it so I rebuilt it this past summer new bearings, seals steering tube and ball but. Steers beautifully now. I filled it with 1/2 gear oil 1/2 grease mixture...sort of a pudding consistency. I park it under cover now to keep water out of the box.
Apogee
Jan 22, 2012
518
Tacoma, WA
Excellent!
The only other thing to consider is running a diesel fuel additive to keep the pump and injectors lubricated, prevent the fuel from gelling and to take care of any moisture or algae that happens to be in the fuel. The injection rebuilding house will have something that they recommend. The older tractors weren't designed for the low sulfur diesel so they need a bit of extra lube added to the oil. It will make the pump and injectors last longer.
As long as you keep up on the maintenance she will last a long time.
Best,
Steve
84cj
Bx1800, 60 inch mower, front snowblower and bucket.
Aug 8, 2013
76
Gorham, Maine
What Steve said. I use 911 as it's available pretty much everywhere. I was concerned when I got fuel last year and it was no longer blue tinted. Found out it's low sulfer and additives are highly recommended for older diesels. I use it with my 2003 Bx.
pejepscot
Kubota L260
Aug 12, 2014
60
Topsham, ME
Hey, guys! Well I got the pump and injectors back from the $hop. I reinstalled everything lining the pump back up with the ledger mark on the engine case. I bled all the air out of the fuel lines, gave her 45 seconds of glow plug and hit the starter... Success!!
I just worked her hard for 2hours moving huge snowbanks back and she seems fine - except she is LOUDER than before. This means she is REAL LOUD. Could the injection timing need tweaking? How the heck would you know if the injection timing was a little early or late? It's not like I can stick my timing light on there and test it....
Any ideas?
5,357
Loud? Like it needs a new muffler loud?
Is it blowing any smoke?
Doggy under a load?
Won't idle?
Won't rev Up?
