Hello All,
First post here at what seems to be a great reource with very useful information!
This past summer I sold my first tractor, a BX 24, in order to purchase an older, larger L2650. The tractor now has 1400 hours and I need to perform a few maintenance projects this winter. I previously changed all fluids and filters in the tractor during my first month of ownership so I'm good to go in the routine maintenance department. Now I need to address other issues that I knew about when I purchased the tractor.
First on my list is gear oil leaks on both sides of the front gear housings - I'm assuming seals need to be replaced. At the same time, both tie rod joints need attention. Both rubber dust boots are torn and the right side joint has a good deal of play. I want to tackle both projects at the same time.
Does anyone have any input as to the complexity of what I need to do? Any special tools required? Is this something I can accomplish in a matter of hours?
Since I will be using the tractor w/ a 6' rear back blade for snow removal, I need to make sure I have my ducks in a row to minimize down time before I start these repairs.
Thanks in advance for any help!
