instrument panel
lugbolt
ZG127S-54
Oct 15, 2015
5,501
2,207
Mid, South, USA
If I remember correctly it just pops out. On the front of the dash there is a slot. Use a flat object in that slot to pry the two pieces apart.
olekid
B7510,loader, Curtis heated cab, loaded tires snowblower,grader blade,snow plow
Apr 9, 2013
92
Mount Uniacke, Nova Scotia
Thanks lugbolt, saw that slot and tried to pry, did not move much, was to cautious maybe, so I will try a little more pressure.
olekid
Apr 9, 2013
92
Greetings lugbolt, you were right, just needed a little more pressure and it popped out, thanks again for your help, really appreciated it.
Pignout
M8200, L35, L39
Jun 1, 2020
9
Olympia, Wa
Only got 1 eye and can't see what is holding it from coming out. Any help Removing instrument panel on a L35 so I can install the new ignition switches
