O olekid Member Equipment B7510,loader, Curtis heated cab, loaded tires snowblower,grader blade,snow plow Apr 9, 2013 92 8 8 Mount Uniacke, Nova Scotia Feb 6, 2019 #1 Greetings, can someone help me, how to remove instrument panel from dash on a B7510?
L lugbolt Well-known member Equipment ZG127S-54 Oct 15, 2015 5,488 2,194 113 Mid, South, USA Feb 6, 2019 #2 If I remember correctly it just pops out. On the front of the dash there is a slot. Use a flat object in that slot to pry the two pieces apart.
O olekid Member Equipment B7510,loader, Curtis heated cab, loaded tires snowblower,grader blade,snow plow Apr 9, 2013 92 8 8 Mount Uniacke, Nova Scotia Feb 7, 2019 #3 Thanks lugbolt, saw that slot and tried to pry, did not move much, was to cautious maybe, so I will try a little more pressure.
O olekid Member Equipment B7510,loader, Curtis heated cab, loaded tires snowblower,grader blade,snow plow Apr 9, 2013 92 8 8 Mount Uniacke, Nova Scotia Feb 8, 2019 #4 Greetings lugbolt, you were right, just needed a little more pressure and it popped out, thanks again for your help, really appreciated it.
P Pignout New member Equipment M8200, L35, L39 Jun 1, 2020 9 0 1 Olympia, Wa Yesterday at 3:35 PM #5 Only got 1 eye and can't see what is holding it from coming out. Any help Removing instrument panel on a L35 so I can install the new ignition switches
