Hi guys, new member from Australia here. I have 2 x B7001 tractors and a B6000 and I’m just replacing the injector pump on a B7001 and all the numbers and even a google search show up as a D850 pump. I only really need the bottom slotted washer from the spring seat inside the pump but I thought i might as well just get another pump as I can’t get a washer anywhere in Aus but only over priced second hand pumps. Every wrecker here wanted $400 USD minimum for a pump, so I sourced one from over seas. Does anyone see reason why the D850 pump is different to the 750 as the only obvious sign is the locking spring that I can see via pictures and I also seem to get various item descriptions and tractor models via the web. One last thing that’s stumped me is I cant find the access hole to view the flywheel for timing of the injector pump and there seems to be no easily identifiable access cover. Would it possibly mean I have to remove the starter to view from inside the starter hole. Thanks in advance Jamie
