Inexpensive Snow Blower Upgrade!
Victor Machine Works
LX2610, LA535, Lx2963, Homestead 55" Grapple, LandPride RB1672, Howard HR30
Dec 17, 2023
Maine
This is an easy and inexpensive upgrade for the deflector chute of your snow blower. I got the idea from a member of this forum (before I was a member) but I cant seem to locate his post to give him credit, sorry! In his post he also did a nice clean install. Anyway as I've been reading this forum awhile and getting good ideas and info I figured that it was time to join and contribute.
Parts List:
$40 linear actuator from amazon
$6 project box from amazon
$15 Latching panel mount plug from amazon
$15 2strand 18 gauge wire from amazon
$8 1/4 Braided cable cover from amazon
$10 double pole double throw momentary toggle switch from amazon
A couple of 1/4 npt cable glands that I had lying around (also from amazon)
A piece of 3"x10" CRS and a length of 1/2" ID pipe for the cable guide.
Just a bit of welding for the cable guide. I pulled my 12v power from the rear 12v auxiliary outlet behind the seat. I did have to drill and tap 2 holes to mount the project box (junction box) but with the Latching panel mount plug it makes for a nice quick disconnect for removing the blower. I had previously modified my joystick with a piece of 1" aluminum pipe with some heat shrink over it for the land pride third function kit (to aid in hiding all the wires) so I 3d printed a toggle switch mount out of a carbon fiber material to mount the switch (and hide the wires). (I think with a little Enginuity one could also use a "project box" for a toggle switch mount on the joystick and have it come out nice and clean). My goal was to have it look and feel as factory as possible and I think it came out pretty well. Anyway I hope someone can get some inspiration from this and I'm happy to help if anyone has questions or concerns please let me know, Thanks!!...... Inspiration for this Project came from member DonyStoy, Thank You!!
Reactions: 10 users
Dustball
2016 B2650HSDC
Sep 15, 2023
273
153
Hudson, WI
Looks great! Are you willing to print/sell a version of your switch housing but to fit the factory 13mm loader lever diameter?
4,810
That is pretty slick. The only problem that I saw was the tag that says "on-off" instead of "up-down". ;)
2,732
Very clean install sir! That looks Factory (or better).
I really like that 3-d printed mount.
Welcome aboard!
woodman55
L6060HSTC, RTV 1100
May 15, 2022
926
720
canada
Parts List:
Just a bit of welding for the cable guide. I pulled my 12v power from the rear 12v auxiliary outlet behind the seat. I did have to drill and tap 2 holes to mount the project box (junction box) but with the Latching panel mount plug it makes for a nice quick disconnect for removing the blower. I had previously modified my joystick with a piece of 1" aluminum pipe with some heat shrink over it for the land pride third function kit (to aid in hiding all the wires) so I 3d printed a toggle switch mount out of a carbon fiber material to mount the switch (and hide the wires). (I think with a little Enginuity one could also use a "project box" for a toggle switch mount on the joystick and have it come out nice and clean). My goal was to have it look and feel as factory as possible and I think it came out pretty well. Anyway I hope someone can get some inspiration from this and I'm happy to help if anyone has questions or concerns please let me know, Thanks!! View attachment 118186 View attachment 118187 View attachment 118189 View attachment 118190 View attachment 118191
Impressive. Better than factory, I would say.
Donystoy
Dec 10, 2013
559
214
Binbrook, Ontario
Looks similar to mine that I did last year. My switch is on my dash as I have a third function switch on my joystick. Have under $100 in it. Just could not see spending mega bucks on the oem hydraulic system to move a deflector that you can move with one finger.
Yooper
3901 LA525
May 31, 2015
1,524
528
NE Wisconsin
Got me thinking about getting a 3D printer…again! Very professional looking!
3,280
Looks real nice, I would like to see it work.
Oh and one thing, we had a gentleman on here that did tons of mods to his and other Kubota's. And he posted them to help others that may want to do the same thing. Some were simple others down right ingenious. Most of the old timers here know of whom I speak.
Turned out there are some unscrupulous people, that desided to take his ideas and run, makeing bucks of them and labeling them as their own and he got nothing out of it.
I only mention this, as a cautionary tail.
monkers1212
BX 2380
Jul 13, 2022
Catskills Ny
That looks great! Nice and clean. Where did you get the "plug" going into that little outlet type box? Great work, thanks for sharing it!
torch
Jun 10, 2016
2,617
864
Muskoka, Ont.
Looks great! The only comment I have is consider inverting the linear actuator, so that moisture can't run down the piston into the mechanism.
Dec 17, 2023
Maine
Thank YOU!! Yours was the inspiration, (sorry I couldn't give you credit in the original post!) I really liked the way you managed the wire. I believe I ordered my actuator seconds after seeing you pics, so thanks for helping to fuel the fire!!
Dec 17, 2023
Maine
the plug that i used was a Clinko from amazon, but an amazon search of " 2wire panel mount plug" will pop up dozens to choose from.
Donystoy
Dec 10, 2013
559
214
Binbrook, Ontario
Happy it worked out for you. Besides the actuator and the switch mine was cobbled together with "stuff" that I had kicking around. The post to hold the wire was some 3/8" threaded rod with 3/8" gas line over it and topped off with the perfect rubber cap that I had in a junk drawer. Most of the wiring was left over from car wiring harnesses from my restoration days. I just have a 2 wire plug similar to a trailer plug hanging out from under the front grill. Mine is a cab model so it was a bit tricky to route the wire. The feed for the switch was tied into the feed to the accessory socket (cigarette lighter socket) on the dash.
