I should have bought a Tonka
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,977
2,357
Western MT
well if you can afford to BUY a Mercedes, you can afford to repair it !!
Probably true for new ones. Used Mercedes don't keep their value that well. There's a reason for that.
The cost of maintenance on a Mercedes compared to other vehicles is high. Older Mercedes are very expensive to maintain.
WAS BANNED FOR NSFW PICS
5,164
My Mercedes was such a lemon and was always going in for warranty repairs. One day the factory rep was there and I asked him what was I to do with the car when it was out of warranty. He said to buy a new one because you don't want to own a Mercedes out of warranty. At that time they didn't offer an extended warranty at any price. I sold the Mercedes and bought a Ford and an 8-year 100,000-mile extended warranty. Sure it doesn't have the prestige of the Mercedes, but it cost half and almost everything is covered under warranty.
5,188
$200 /hr = 60 for mechanic, 60 for overhead, 60 for profit, 20 for coffee.....
I bought my E350 when it was 6 years old (now 9 yrs. old)
Had 60K, and was in excellent condition -$15K.
They are often relatively cheaply priced as used cars, due to known high maintenance costs.
I never go to any dealer for maintenance/repair.
Dealer price (Jan. 2020) for new plugs was $1,034.89
I replaced the 6 plugs myself, for $76.
Replaced all filters, and fluids, 2 (yup) batteries, driver seat bottom leather cover, tires, & wiper blades.
Still have the car, and love it.
Getting too old now to fix much stuff myself, but will still never go to a dealer.
Alfred_2345
L3901, LA525, BH77, SGC1060, RZ60, Box Blade, Z726XKW ZTM, RTV-X900
Jan 5, 2023
134
65
Northwest Arkansas
Kubota has made an improvement to the ECU for your tractor and superseded the part number
Your ECU has been SUPERSEDED. (replaced with updated one)
Not sure I would use "improved". I like the "superseded" term better. There may not have been anything "wrong" with the original.
We don't really know why Kubota changed the part number but with the electronic component shortage (i.e. supply chain), it's likely they did so because they couldn't get parts in a timely manner.
I worked as an electronics engineer at a contract electronics manufacturer and we built ECU/EMMs among many other things. In the last two years, most of the customers were revising products due to component availability/lead time issues. I heard some components were out to 70+ weeks lead time.
5,515
2,228
kubota never tells anyone why they change a part number. On ECU's I'm surprised it hasn't been changed much more often, a lot of mfg's do that. Vendor changes, color changes, and the many software changes on pre-programmed ecu's. Gotta keep the epa happy.
Then they have enhancements. If kubota sees a high failure rate of zener diodes within the ecu, they'll ask bosch (or whomever the maker of the ecu is) to beef that area up, which can entail other changes, negating a new part number.
or if the ecu stands out like a sore thumb and kubota says paint it gray, yes another part number. Or if the gray paint doesn't quite match the frame. Another part number. OR (here's a good one) if the fenders coloring fade to pink, they'll change the paint process and yes another part number. I think some of the older M series guys can relate to the pink kubota statement....
or if the original vendor (who supplies it to kubota) jacks the cost up 250% and kubota can find another one from a different vendor, with the same program, connection, etc, for 5% more than what it was, they'll change the vendors--and thus the part number.
assigning a part number to an original part doesn't mean that part is going to remain the same throughout it's service life. FORD...FORD's internal part numbering system, if one doesn't know a little about it, will confuse the daylights out of you. They're notorious for this. So is Yamaha. All manufacturers do it, be it to save cost, to improve the product, meet standards, whatever-but they often change the part many times in it's lifetime.
The end result is that consumers (myself included) look at it all as purposeful deliberate confusion.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
561
190
NZ
OK I give up, can someone explain what an ab tonka is? Googled it, no such thing. Tried to figure out if its a fat fingers typo (I am prone to those) but still can't work it out.
3,580
I think he meant "A TONKA" as in a Tonka toy would have been more reliable.
JohnDB
Jun 9, 2018
561
190
NZ
Aaaah, Ok. If that's what he means, pity someone can't correct the spelling to help comprehension.
BX23-S,57 A-C D-14,
6,321
SCE = Spell Check Enabled
I get a few 'interesting' emails for people with so called 'smart devices'....
I also still have my late 50's TONKA lime green dragline and 2 of the pickups,here, somewhere....
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,214
3,564
SIE= spellchecker iz bustimicated
I have my 70' s Tonka excavator. There was a dump truck that went with it but that's gone.
cthomas
LX2610 HSDC
Jan 1, 2017
866
576
La Farge Wi
Had a 1999 Mercedes E320 4matic wagon(116k miles) that I bought in 2008 for $1600 that someone had the owner convinced that it had transmission/4wd issues and BIG money to fix. Found it had a wheel bearing that was so bad to the point the brake caliper was wearing on the brake rotor. I spent around $2000 to fix everything on the car(tune-up, fluids, filter, brakes, wheel bearings, tires, and water pump). Drove it for 3.5 years and another 30k miles without issue. Also had a 1981 E300 Mercedes the had 320k when I bought it with a bad engine(the replacement engine was out of a wreaked 85 E300SD(TURBO!!). Drove that for a few years and damn talk about a car that was over-engineered. Windows switches that a average person could rebuild with a nail file. It was build to last as it had 350k on it when I sold it and the seats were worn but not torn/ripped/failing. I used/abused this like it was a truck(used engines and transmission hauled in the wagon) Also had a customer(Mercedes E190)that got 15 years out of the original battery(every year I had to convince her not to replace the battery as it still tested good). Every manufactory has a few bad products.
