I messed up....
cforand
Tractor/Mower
Aug 5, 2019
Texarkana
So over the weekend my Kubota ZG222 had a dead battery, I jumped it off and had running but it died on me again. I jumped it off a couple of times but the last time I reversed the jumper cables and now the mower is dead. I did install a new battery and replaced the 15amp fuse under the seat but it still wont do anything when I turn the key. Any thoughts on what to check? Figured it could be ECU or starter but didn't know if I should look at anything else.
Thanks guys, looking forward to getting to know everyone here.
Craig
Tughill Tom
B3200
Dec 23, 2013
1,235
1,403
Turin, NY
Craig
I don't know that machine, But you may have burnt out a Fuseabile link. Time to put a volt /Ohm meter to work and trace it out.
SidecarFlip
Banned
555
if it has an ECM, chances are you fried it.:)
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Check your owners manual against THE ONE SHOWN IN THIS LINK for a 50 amp slow blow fuse (circled number 2 in picture). The Protected circuit for the 50 amp fuse says "Check circuit against wrong battery connection" which is what you say you did.
Also, welcome aboard to OTT.
SidecarFlip
Banned
555
Wow, 10 grand list for a lawn mower, Im amazed. Thought my 60" Cub Tank was expensive at 6500
5,689
Flip, is that much different then the motorized wheel borrow you wife just bought? Why do you have to be negative on what others purchase. Sometimes passing over a thread is OK.
