This is a good point!
Force pulling on the draw bar (it being below the rear axle) will cause the front of the tractor to be pushed down.
But as sheepfarmer says, if the rear wheels do not lose traction, a force lifting the front of the tractor will be developed by the engine power to the rear wheels.
IF the rotational force of the tires on the rear axle exceeds the force generated by the pull on the drawbar, which is below the axle, the front of the tractor will lift.
This must of been the situation that Skeets experieced.
Do not recall this ever being pointed out in safety literature I have read in the past, related to the reasons why using a drawbar is the safe way to pull something...
I think we have the answer to what Skeets experienced!
Added thought: As the front of the tractor lifts, due to the geometry, the force generated by the draw bar increases, so there is a bit of self correcting action that occurs, tending to oppose the lift of the front of the tractor...how much this help, no clue here...
