to be a youtube mechanic...
Watch the video, can you spot the shortcut I did?
https://youtu.be/HmW0INIEbaU![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Bingo, I just hooked a couple of hose removers, popped the hose off, removed the air cleaner and moved the round brace for the AC/ALT bracket, then unscrewed the the gooseneck bolts and removed them with needlenose pliers, then had to twist, rotate and jiggle the gooseneck off. Total time about 40 minutes, to remove. (most of that time was running for wrenches, pliers etc,as I parked the truck by the water hose, for easier filling, when I finish up!) I plan to stick the bolt heads into a hose, and start them thataway, when I replace everything. My truck is not exactly like the one in the video, the bypass hose is really in the way, of that back bolt, so I might run into trouble on re-assembly...That video was a thermostat replacement. I dont recall ever removing ac/alt or bracket to do it. Perhaps it was too traumatic and i blocked it from my memory.
I didnt notice a short cut there. Biggest one for me is air ratchet.
Yer a wizard! Maybe even a whizard!Got her all back together this AM, Took about 15 minutes...
... good thing I didn't watch the video before trying this...![]()
Yer a wizard! Maybe even a whizard!I'm glad I watched the vid before you said how you did it. I could see some unnecessary moves, but you make it clear that it's not that bad a job if yer not a roket sighentist!
Say, when you get it glassed up and ready, how about coming down and opening the driver door of my Transit Connect? The latch mechanism is seized and I'm getting tired of climbing in and out through the window.Took it to the Fart dealer and the repair cost (almost $700) is more than I can handle.
Missed my chance yesterday when a huge dump truck went tearing through an intersection going about 60, a good five seconds after my light turned green -- I think it might have bumped the door hard enough that his insurance company would have fixed the latch.Unfortunately, I was second in line, and the cretin ahead of me must have been texting her BFF.
I'm real close to taking my Dremel to the door panel and start trying to disassemble the latch from the inside!![]()
Not to me -- it hid that vid from me, but served it right up to you! Guess they are pi$$ed at me for spelling it "Giggle" eh?
Dunno which is funnier, english having a "safety bat", or OSHA approving anything english.Prolly an english "safety bat" OSHA approved...![]()
