Hydraulic valve help
Yooper
3901 LA525
May 31, 2015
1,644
787
NE Wisconsin
I thought I'd start a new thread because I'm probably boring half of you to death with my stump grinder build.
I'm at the point in the build where I have to figure out the hydraulic valves. For the up and down and sideways, I purchased a joystick valve which will take care of the bulk of the work. (Thanks Wolfman for the suggestion!)
I want to go with a solenoid valve to engage the hydraulic motor that drives the cutting wheel. I know it can't be a regular on/off type because the inertia of the wheel spinning will turn the motor into a pump as its winding down. There has to be a path for this oil to go. In my research, I see solenoid valves listed with a 'motor spool'. Sounds like what I need, but I have no experience with them. Can anybody educate me in the right type of valve? This would be actuated by a switch on my dash.
The other challenge is the extend/retract cylinder. I need a solenoid valve that will send pressure to the lock cylinders when in the 'middle', but release the pressure and engage a cylinder forward or backwards when energized with a three position switch. Is there even such a valve? If so, this would allow me to control the grinder with one handle, which would be awesome!
Looking forward to the replies on this!
5,257
1,043
Yopper
Seeing you have not had any responses to your Aug 14 post, I would reluctantly make this suggestion.
Become a member of the other forum as well as this one.
http://www.tractorbynet.com/forums/members/j_j.html
There is a guy identified as J_J who is an absolute wizz when it come to hydraulics.
Try posting in the hydraulic section of this forum and even send J_J a personal message.
He was a big help for me.
Alphonse
L-35
Feb 16, 2016
Lanco, Pa
Yooper
I hope you have everything sorted out by now.
Sorry I can't tell you HOW to do this, but YES the gear exists.
I will verify the vendor and see if they sell retail.(I've been retired fifteen years and not in that loop).
Also I think you could configure the cutting wheel drive to more or less brake instantly if desired.
Kennyd4110
Vendor Member
Sep 7, 2013
1,358
671
Westminster, MD
www.boltonhooks.com
Sorry I've just seen this...
Yes, you want whats referred to as a "motor" spool valve or sometimes called "open center" where the work ports are open to the tank in neutral-this is opposed to a "tandem center" valve that has the work closed in neutral to hold a cylinder from moving.
I'll assume 12 volts, so one like this would work perfectly (with the proper subplate of course)
http://www.surpluscenter.com/Hydrau...-GPM-OC-MOTOR-SPOOL-SOLENOID-VALVE-9-6137.axd
Or:
http://www.northerntool.com/shop/tools/product_200329577_200329577
Yooper
3901 LA525
May 31, 2015
1,644
787
NE Wisconsin
If you go to my 'Stump grinder build' thread, on the last page I have a picture of the valves and their purpose where I pose a few questions.
