Not sure what happened, but the hydraulic top link on my B2650 is leaking right behind the washer where it mounts to the top link tube. Yesterday while doing ground work I noticed a small leak, which then started squirting. Found the nut itself was loose, so I tightened it up (snug/firm, didn't go Hulk on it). That seemed to slow to stop the leak, but shortly later, it loosened back up. I re-tightened (same amount, maybe a smidge more) and it still had a slow drip. I don't think I should tighten it anymore, it's literally at a stop, I'd have to put some serious torque to go any farther. Leak still comes out from behind the washer. I'm assuming the hydraulic top link tube is bad or broke, less than 20 hours on the tractor, so I'll call the dealer tomorrow and see what they recommend. Figured I'd run it by the experts here and see what you guys and gals have to say!
