Hydraulic question
7,158
It will work, just not very well. :(
The GPM's are to high, good loader control comes from a matched valve, You need a valve in the 5 GPM range, more is not better in this case, leads to a lack of control.
Also that valve is cheap because it has all BSPT ports, will get rather pricey and a PITA to get the right adapters to convert it to your piping and hoses.
Also note how many hoses come of the feed side of the valve?
2 or 3, 2 means no power beyond (so you would need the plug) and 3 means you need power beyond.
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
11
Gambrills, MD USA
Try looking on surpluscenter.com's site, for a valve with the specs that NIW provided, They have a lot of hyd stuff, there...:D:D
