Hydraulic pressure
draumer
L2402
Mar 4, 2025
Holland
Hi there, i have a l2402dt Kubota,
I would like to increase the hydraulic pressure.
My question is where is the pressure relief valve to be found on this tractor, and how can i change the pressure, shim based, or screw based.?
Thanks for the reply.
7,660
First question is why?
Second question, are we talking about this tractor (pic below), or since you are in the EU a newer tractor.
Since kubota has found it smart to reuse tractor model numbers, yes can be a little confusing.
draumer
L2402
Mar 4, 2025
Holland
Hello, yes it is the tractor like in the picture, its a older model.
The front loader is in my opinion to weak, with a gage i would like to check the pressure.
But also like to now where the control valve is situated, and how to increase or decrease the pressure.
And is there a shim kit available in case of need.
7,660
You're going to have to give me some pictures of the hydraulic plumbing.
From the pump and all the loader lines and loader control valve.
You could have one or more relief valves in that system.
