B2320 HST. is the transmission oil and the hydraulic oil the same oil when draining and changing. My owners manual is not clear
Thank you. My manual says change trans filter at 200 miles and hydraulic filter at 400 miles. Just not clear so my question. Thanks for your replyYes - there are the same, however - I believe if memory serves me, there are several drain plugs.
It will take something like 4 gallons to fill!!!
Do you know if I can change a filter without draining fluid?Thank you. My manual says change trans filter at 200 miles and hydraulic filter at 400 miles. Just not clear so my question. Thanks for your reply
RIGHT! Hours. SorryI think you mean 200 and 400 HOURS!
Thank youYou can. Creating a partial vaccum with a shopvac over the hydraulic oil fill hole makes it easier as you lose less fluid. Just make sure that the old filter gaskets came off before installing the new filters.
