Hey all,
In need of some help.. again. Yesterday I finished up a front crank seal and hydraulic pump seal on my B7200HST. When I went to test the hydraulics (FEL) everything worked fine except it seemed a bit slow at first. Then I realized foamy hydraulic oil was quickly overflowing from the vent hole. It didn't do this before I serviced the pump. The pump didn't leak at all until right after I shut the engine off, only did it once and now it appears it isn't leaking.. high pressure maybe?
Is it just air? If so how would I bleed it out?
Also is there a good way to check the suction side of the hydraulic system? I assume you can't just spray connections with soapy water.
Also could a small amount of water contamination cause my symptoms? I had the Hydro oil cooler off when I started to hose down the engine, quickly realized it was off - can't imagine a lot could have gotten into the line.
