Hydraulic leak
Jones150
Kubota l3600
Jun 13, 2025
Alabama
I have a Kubota l3600 glide shift transmission that’s a paste 90s model. I have a real bad leak where I have to keep refilling the rear end before use. Has anybody ever tried to repair the glide shift cable assembly? One side has pulled out slightly and is leaking fluid out from there. Also has anybody had common places for rear and leaks in the past?
8,843
The cable assembly does not stop it from leaking.
There are O-rings or seals on the GST valve.
You will need to give me the serial number for me to tell you which one it uses.
