Hydraulic hose size for snow blade
NS kubota
Kubota MX4800, Norse 350 logging winch, Hla 2042 pallet forks, Woods BSS60
Dec 21, 2014
62
Nova Scotia, Canada
Just trying to figure out what size hydraulic hose I need to run our hydraulic power angle plow blade we are hooking up on the FEL. The hydraulic lines on the loader look to be 3/8" which should supply enough flow for the 2 cylinders. We are going to run 2 new lines from the rear remotes to the front blade so we will still have full function of the loader and bucket curl. Thanks in advance for your input.
Tooljunkie
May 13, 2014
4,150
30
3/8 is fine,myself after running hoses the length of the tractor i would even consider 1/4". Doesnt take much oil flow to angle a blade.
NS kubota
Dec 21, 2014
62
Nova Scotia, Canada
Thanks Tooljunkie I will likely go with 3/8 just in case I decide to hook up something else down the road. Cheers
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
Exactly what Kenny said. 1/4" was easy to route. Its only angling a blade, dont need a ton of volume...
NS kubota
Dec 21, 2014
62
Nova Scotia, Canada
Thanks guys I had another look at the tractor & loader and 1/4" will work better, thanks again and happy tractoring
Tooljunkie
May 13, 2014
4,150
30
The 3/8" is a little less forgiving,i strapped the pair of hoses together thinking it would be better,had to cut straps and redo because they dont bend /twist to shapes you want them to lay. 1/4" will also find its way through smaller gaps.
I used 1/4" for the truck plow on my truck. Pump is in the back of the truck,mounted by the hitch. Routing hose was easy.
I think the only time you will notice a problem is when its real cold,it will be a little slow until tractor warms up.
NS kubota
Dec 21, 2014
62
Nova Scotia, Canada
Thanks again tooljunkie good to get some feedback from someone that has experience trying to route hoses etc. Also good to hear from a fellow Canadian.
