I have a L2350DT with a front loader.
I would love to have a small front mounted Hydraulic winch for my tractor. Something along these lines:
My question is:
Could I use some type of 'diverter' to supply the winch with the hydraulics used for the front loader and thus use the spool valve to operate the winch (in and out)?
The object being able to use the front loader (not at the same time as the winch), switch the diverter and then operate the winch as needed.
I'm not well versed on hydraulics so any ideas would be welcome. I don't know the pressure or GPM requirements of the winch versus what my tractor output is, so it might not even be possible.
Thank you in advance.
Flint.
VEVOR Industrial Hydraulic Winch 10,000lbs, Hydraulic Anchor Winch with 24m Strong Steel Cable, Hydraulic Drive Winch Adapter Kit, Utility Winch with Mechanical Lock for Tacoma Yukon Hummer, etc. | VEVOR US
Discover VEVOR Industrial Hydraulic Winch 10,000lbs, Hydraulic Anchor Winch with 24m Strong Steel Cable, Hydraulic Drive Winch Adapter Kit, Utility Winch with Mechanical Lock for Tacoma Yukon Hummer, etc., Sturdy Aluminum Alloy and Strong Steel Cable at lowest price, 2days delivery, 30days returns.
www.vevor.com
My question is:
Flint.
