E Erz16 New member Equipment Kubota B7500 tractor Dec 23, 2022 16 1 3 Missouri Jan 2, 2023 #1 It’s a B7500, easy fix or more complex? I’m a first time Kubota owner.
mcfarmall Well-known member Equipment Kubota M5660SUHD, Farmall C Sep 11, 2013 1,390 1,661 113 Kalamazoo, MI Jan 2, 2023 #2 Depends on your mechanical abilities.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,263 5,568 113 Sandpoint, ID Jan 2, 2023 #3 Yea what he said! It's just a matter of disassembling the cylinder and replacing seals and reassembling it. I will say that's one of the easiest cylinders to disassemble, you just need a gland nut wrench to get the end off.
E Erz16 New member Equipment Kubota B7500 tractor Dec 23, 2022 16 1 3 Missouri Jan 2, 2023 #4 Watched a few YouTube videos. Basically have to take cylinder arm apart and replace the seals. I assume a Kubota dealer has the seals. I hope.
My Barn Active member Equipment Kubota, Ford Sep 14, 2022 135 37 28 Michigan Jan 2, 2023 #5 Make sure the cylinder has no scratches...Or it will destroy the seal again!
Matt Ellerbee Well-known member Lifetime Member Equipment MX6000 Jun 27, 2019 1,774 2,014 113 Canton, Georgia Jan 3, 2023 #6 Erz16 said: Watched a few YouTube videos. Basically have to take cylinder arm apart and replace the seals. I assume a Kubota dealer has the seals. I hope. Click to expand... Price the seals at the dealer. Then call a local hydraulic shop. It may be cheaper to have the shop do it. Shop I use is $90-$150 for repack.
